Draggin the Pegs
Draggin the Pegs
I have a 2006 St Bob and I am interested in how far over you can lean and still not have the bike slide out from under you. We have a lot of twisties here in Northern California and I drag my pegs nearly every time out but I want to know if there is any more room to lean or is the side of the road is the next stop. On the right side the peg drags and thenthe pipes and I won't lean into the corner anymore than that. But I always wonder if it will go down if I stay leaning in. My feeling is that the suspension may lengthen with some of the weight on the pipes and maybe it will stay up at that angle with the pipes draging. Factory Pipes(They are already scratched) Then on the left side when the peg drags I feel that the primary cover is next and I know that I don't want toscratch that. But how much further after the peg hits is the cover going to hit? I know that the pegs draging is a warning sign but sometimes you are commited in a turn and you really can't slow down or straighten up safely, so there you are. SO the question is, is there anymore room if you find that you are in a decreasing radius and need a little more lean? I also realize that the tires and road surface are a major factor but what I am tryng to ask is how far can you lean before you are gone no matter how favorable the conditions are. I am sure that I will get some (what kind of moron are you) responses but it issomething I think about when I find myself in a commited situationand a little more angle would be helpful. Is there something that you can feel or hear prior to the sliding and crash noise?
RE: Draggin the Pegs
I hit the pegs and drag the pipe through the curve makin an awfull noise, I am gonna put a titanimum strip on it so it will throw sparks at night[8D].
I run my shocks at 1 up from the softest setting and have found that in turns where I tend to push the outside if I roll hard on the throttle it squats the rear and lifts the front giving me a tighter turning radius.
It's all it the torque.
I've been draggin stuff on mine since since day one, from what I've heard at some point the exhaust system will lever the rear wheel off the ground which I've heard is not pleasant.This hasn't happened to me yet, possibly because I cranked up the rear suspension to the max which will put a stop to most of the grinding.Where abouts are you in N.CA? I live in Templeton and work in San Luis lots of cool curvage to ride around here if you have time, he types on a company keyboard.
ya pegs, pipes, kickstand, but never the primary yet anyways. what i've been doing is just slightly lifting my foot off the peg in the corner so it doesnt buck your foot off when it hits, instead it just quitely pushes the peg up as you lean. theres not even much of a drag or scrape sound that way and it dosent grid off much of you peg each time. how fars too far....well thats all up to you really i imagen like special ed said the pipes could cause the rear wheel to lift lossing traction and yer takin a dirt nap but i think you'd have to lean hard and be goin pretty quick to get that. it does sux all the draggin i ran with some rockets thru the mt twisties and man i freakin drug everything but i was stickin with them rice eaters pretty good but after 10mi or so of throwin that 600+ lbs bike around i had to back off a bit. anyway thats my story and im stickin to it
Thanks guys. It is comforting to know that others have the same problems and so far the rubber side has stayed down. And for SPECIAL ED I live just outside of Sacramento and do a lot of my riding in the Gold Country/Foothills of the Sierra's. It gets hot here, 100+, in the summer months and the temp drops considerably if you head for the hills. It can drop 15 to 20 degrees in 35-40 minutes heading East on I 80 toward Truckee and Lake Tahoe. I wish we had the kind of temps that they have in San Luis Obispo and the Coast. But all in all we have what I consider pretty good year round riding conditions here, generally between 35 and95 degrees.
ORIGINAL: jonpiper
I really dont see the point in doing that to a expensive HD .... sad thing is a cheaper decent sportbike will kill you guys in curves .
bragging about dragging parts of your bike on the concrete is about as cool as an arsehole on my forearm .
ORIGINAL: jonpiper
I don't see the point in paying all that money for a bike and then not riding it however the hell you want. Life's too short to worry about dragging a three dollar exhaust bolt. Give me a break! My pegs were $125 and I don't squall anymore when one touches the ground.
