Front Turn Signal Relocation
Do you need to remove the wiring from the handlebars instruction? Or a bracket to put on the forks?
I just did mine, I did my relocation at the same time as I switched out bars so it wasnt too difficult. You basically just unplug them from the harness thats tucked into the front of the frame opening and I relocated mine onto the front forks with this clamp on Amazon
Check your fork sizes if you go with the clamp option, mine is 49mm.
joker2041
04-12-2020 03:06 PM
