Wiring front sigs?
Old 04-25-2017, 03:25 PM
jqb12's Avatar
jqb12
jqb12 is offline
Default Wiring front sigs?
This is what Im looking at (pics). So Im thinking I need to:
1. Attach to the lower tree pinch bolts, several options out there.
2. Solder 3 wire extensions to the three coming out of the bulb (blue, purple, black)
3. Connect the correct terminal pins to fit the connector in the pic.
4. Plug that connector into the Female-type connector under the tank, on both sides.
Am I correct here? If not, please inform
Thanks, Jeff
Old 04-26-2017, 12:06 PM
esteboatan's Avatar
esteboatan
esteboatan is offline
I would say your right. I just had my handlebars off and decided to do the turn signal relocation to the forks. Here is a pic of the connector wired up. (left connector is the turn signal, right is part of the control switch)
Old 04-26-2017, 09:56 PM
jqb12's Avatar
jqb12
jqb12 is offline
just want to be sure I know what I'm looking at. Is the wiring in the left in the pic, what plugs up under the tank? That white connector
Old 04-27-2017, 10:45 AM
esteboatan's Avatar
esteboatan
Yes, there are actually two of them, one for each turn signal, one white, one black. They are located under the tank/in the frame and I pulled them out from the front frame holes.
Heres a better pic of the two
Old 04-27-2017, 09:38 PM
jqb12's Avatar
jqb12
jqb12 is offline
That's what I needed to see, thanks a lot. So you pulled the whole unit out because you were also changing your bars, correct?
Old 04-28-2017, 06:56 PM
esteboatan's Avatar
esteboatan
Yes and it was a pain to get those wires and the control wires through the bars. It was a good excuse to get a turn signal relocation set up and put them on the fork instead.
AllOutGraphics
05-11-2023 11:01 AM
BMCsteve
10-24-2013 10:28 PM
AllOutGraphics
11-18-2012 06:20 AM
Stag556
12-06-2011 08:38 PM
JSHULSE
12-23-2005 10:34 AM
Quick Reply: Wiring front sigs?
