Streetbob swingarm bags?
I took the passenger pegs off this super glide but as you can see they would work just fine.
https://www.legendarycycles.com/coll...harley-victory
Its the Bobber Bag (Softail Style) & Bracket Package for Harley Dyna Glide
Heads up, I spoke with Al at Legendary Cycles regarding fitting a bag to a bike with a side mount plate (i have a 2016 FXDB). He's currently working on the brackets that will allow you to fit their softail bag and they should be done in a couple weeks.
Thanks to Antonio for the tip!
Here's how the bag will look mounted
The bracket that mounts to the shock is universal. I'll probably cut off the excess material and shape it up on the grinder and respray at some point, maybe use threaded couplings instead of the spacers, bolts and washers-you can't see anything when the bag is mounted but it looks ratty to me when I pull the bag. The rear belt guard mount accepts a length of all thread and serves as the second mounting point for the bag.
The metal 1/8th inch plate on the outside of the bag bolts up to an identical plate inside the bag behind a very nice snap in liner. The bag is high quality heavy leather.
The details I'm providing are for the softail style bag for the dyna-not sure if the other bags in this thread mount the same.
Here is a Viking Bag. It is small, but has a hole for a lock. Perfect for registration and insurance. Fits gloves, glasses, a lock to secure a helmet, ETC. Pretty happy with it. Great for if you are only looking for a bit of storage and don't want a large obtrusive bag.
EDIT: bracket was well made and goes behind the belt guard and under the left side passenger peg mount. Was super tight to get the bag on and it does touch the shock (the bag), but I've put thousands of miles on it with zero issues.
