Street Bob upgraded with Low Rider S Parts?
I have a '16 FXDB and there are a number of small upgrades I'd like to do, most especially blacking out currently chrome parts. I just thought of buying OEM FXDLS parts to install on my FXDB as replacements/supplements: has anyone thought of this yet? Some specifics were replacing my current black turn signals with the black turn signals and supports from the FXDLS (Part #s 678007-23, 68277-07, and 678005-23).
One specific spot was the Rear Shock Bolt Cover: I replaced my stock rear shocks with Progressive 444s and had to remove the stock Shock Bolt Covers - and, quite frankly, I had the look of the steel bolts exposed like they are. I was thinking of ordering the Black Shock Bolt Covers from the FXDLS (part #540001-31, I believe) and am wondering if any current FXDLS owners have installed the Progressive 444s while utilizing those stock bolt covers.
Has anyone tried this yet, or even thought of this? Has anyone swapped parts from one Dyna to another? If so, is it mostly trial and error for fitment? Thanks everyone for your help!
Depending on what kind of handlebars you have, I would be careful with the turn signal mounts. The ones on the LRS push the lights up to allow clearance with the tank at full lock. So the mounts are parallel to the bars instead of perpendicular. Personally, I think it looks better than the vertical "stems" such as the Street Bob mount, but you lose a lot of adjustment range. This will affect you if you put on bars that have less pullback. I switched to t bars on my LRS and even with the turn signal mounts maxed out, it still looks a bit "cross-eyed" when viewing the bike head on.
silverfoxesq (04-18-2017)
Looks like I beat you to the signal housing swap. One thing to be aware of is onn the FXDLS the front housings are gloss black, almost every other bike has flat black. I have mine relocated to the forks so the gloss black matches the triple trees better. If you relocate your liscence plate you will need two right
stand offs for the rear
Thats a good looking Street bob you got there
You need to get the Dyna parts list book for 2016 which will tell you which parts will fit more than one model. I used the 2006 book to confirm that the street bob & low rider use the same fuel tank (along with most other parts) which meant that the lr console & tach would fit my sb. The service manual verified that the wiring harness is also almost identical so tach connection was not difficult. Get the factory books if you plan to do much modifying.
Fitment issues vary by options, model, and year. I'm not well versed on the newer bikes but all of the changes I've made have been preceeded by a lot of research and questions.
Thats a good looking Street bob you got there …
Speaking of which, I've been told that most <10" bars won't need new cables and wires during the swap: how did your swap go? Any complications? I like the look of those bars, by the way: those happen to be a pair I was eyeing.
Insanely common. Half the bikes here probably have at least a few mix-n-match parts from other models/years.
