Looking for FXDLS 2016 PCV Map
Hey all, long time lurker, new member here. I recently put on a Bassani Road Rage 2 Mega Power Systems Exhaust. I purchased it alongside a Power Commander 5 from Fuel Moto.
The bike's performance jump has been very noticeable, but something just seems off with the map. I get the occasional decel pop and if I'm opening her up, I will sometimes get a backfire when shifting. It's not horrible and it doesn't happen much, but something just seems off.
I have checked to see if I have a loose connection, but everything seems nice and tight and I have re-torqued everything to spec.
If it's an exhaust leak, then it's got to be the exhaust gaskets, which I'm willing to replace, but I'd like to try a different map first.
The map that came with the PC5 was the one directly from the Dynojet site.
Is there anyone here that might be able to share an auto-tuned map with the same configuration?
It's all stock except for the exhaust.
In the long run, I plan on doing a dynotune, but my dog recently had some health issues and I racked up some money at the vet.
Thanks for the help.
Shame you didn't get a power vision - fuel moto would provide a custom map for your bike.
Since you bought the power commander from them, did you ask if they could provide a map for it? Sorry I can't offer more, only use power visions.
You also don't want someone else's auto tune map, it probably won't be right for your bike.
You're right, it is a shame. At the time I bought it, I didn't realize the PV was 100.00 more. Maybe if I can't get it worked out, I'll see if I can exchange the pc5 with a pv.
I did contact them them one day and told them what I was experiencing. They advised me to add 20% in the 0% throttle column from 1750 to redline I believe. I did as they advised and it seemed to get better. Maybe I should just keep adding 5% and see if it goes away.
Basically, when I'm high RPM and I let off the throttle it winds down with no pop, it sounds great. I then get to 2200 or so and sometimes it will start to gurgle with mild pops. When I'm in that same RPM range, and I pull the throttle to what I would consider 2%, I'll hear a really faint pop and then as the rpms climb, it disappears.
Thanks for the response.
