Gas gauge reads empty, but is full
KevinPerito (05-19-2023)
Tear into the gas tank
1.) Ensure the wiring connected - and the fuel sender actually works
if it does
2.) Then adjust the float
if it does not
3.) Trouble shoot the sending unit
You didn't state the bike - so I'll assume it a newer one.., and of the dyna line
Sending unit is located on the right - under the gas fill
It can be removed without removing the fuel pump (but since you're in there..., and depending on the mileage - it might be a good time to replace the filter / regulator / sock..., and check out / replace the fuel lines)
Any who - the sending unit snaps in (plastic retaining snaps)..., so you can "carefully" unsnap it to remove
If you need to bend the float arm - bend it down..., also while you're at it - bend it to the right as it's likely rubbing on the inner tank wall
At a minimum - if you do this - you'll need to replace the 12 screws.., and rubber gasket holding on the tank cover
It a lot easier than what I make it sound
Questions - ask
Ghost
if it does
if it does not
Questions - ask
Ghost
Once you determine if the 'bogus gauge' is plugged into the wiring harness under the tank, don't even bother to look at the silly thing. Go by how many miles you have on the tank. I know by the fact that I get 40.75mpg at what point I need fuel. The gauge is dependant on a float similar to that of a old toilet tank and you shouldn't count on its reliability.
My gas gauge reads just fine I just have no lo range
I have tried resetting mine .....and can see lo rng show up but 3 tanks later no fuel low light and not range place on my speedometer readout....
Like I said gauge reads fine ... 2005 fatboy 5000 miles now had 3400 when I got it in Aug-sept..... I know its the dyna section .... same gauge ... saw the discussion ...Im fixing to pull the tank and get at the connector as the bike did sit for years really ...I have used electronic grease on connections I have touched ..... but the lo range hasn't worked since I got the bike...
thought some one might have one of those oh yea try this ..... before I tear *** into it....
