Grip question when replacing bars?
Alrigh... I was then wasn't going to replace my bars, going to a gunslinger seat made the 12 inch bars more comfortable, but gunslinger hurt the ***! So I went back to my Mustang seat which is comfortable and now the bars are eh'.
I'm going to a 14 inch bars and want to know how to get my existing grips off the bars? My left grip I know has a poxy in it and is going to be an issue. The grips are comfortable to the hands and I guess I'm wanting to be cheap since I know I'm going to need a new riser too *** my current bars slip on a regular basis everytime I hit a bump...
Thanks
Thanks
Thanks
Thanks
Thanks
Thanks
Separate the grip a wee bit from the bar - then squirt the mineral spirits in
May take a bit for it to loosen the grip..., may take repeated applications
But the grips will come off - unharmed..., and reusable
Lay rags underneath to soak up any run off
Ghost
Rubber grips? Easy
When you do install the left grip you don't need to use any sort of adhesive; I use blue tape wrapped around the bar up against the switch housing, I keep wrapping the tape and test fitting the grip. When the grip is snug on the tape once you tighten up the switch housing the grip won't move and makes removing the left grip a simple process after that...
JackedUpBack
09-23-2013 10:27 PM
