Any one with a Lucky Daves seat (vs stock)
#51
thats funny I wanted the logo and didn't get one 😂 Ordered from revzilla
as as for the seat it will sit you a little up i have a tuck and roll style step in without gripper material and it is grippy enough ran it for 150 miles in the rain with no worries of slipping off it. Takes a couple hundred miles to break in though but after its great
#52
Durham - give me a call at 800 3977009 x 239 and we can get it sorted. Thanks!
Team Saddlemen
Team Saddlemen
If I sent u my saddlemen seat how much if possible to remove side saddlemen logo? I am not disgruntled at all with my purchase. The side logo is not bad, at least on blends in. But I would prefer not to have it on there . I have been thinking about having it altered. Other than that I am very happy with the new seat.
Durham man (01-15-2018)
#53
#54
#55
JuanderBoy (01-13-2018)
#56
I can only compare it to my stock seat, it is a lot better ( I know that's not saying much) in every way. I bet you would not regret the choice of either one. If you do not want the saddlemen logo,you can order it direct from saddlemen, and specify your request. I found that out after I ordered mine from Jp cycles.
#57
It will move you closer to the tank and lock u in. It is a stiffer seat than stock, but the more miles I put on it the better (softer ) it becomes. It also keeps my back more in line.
rauchman (01-15-2018)
#59
#60
Rauchman-
Typically the ride height is about the same however our progressive density foam does not compress or compact under load so the actual ride height may vary depending on how much you weigh and how broken in your seat is now.
Let us know if you have any questions , were always here and available 800 397 7709 , sales@saddlemen.com or direct message us here. Thanks!
Team Saddlemen
Team Saddlemen
rauchman (01-21-2018)
