103" kit vs individual parts
I have been looking at different options for rebuilding my 96" engine at some point. I have looked at the 107", 110" and both require (suggest) a new larger throttle body. Anyways, I started looking at the 103" HD offers ($699), problem #1 is that the kit doesn't come in black, so this has already pushed me away for it. #2 is all the added stuff in the kit that I don't need, i.e. new clutch spring (replaced mine when I added Barnett clutch parts), Stage 1 air cleaner (already have the Ness Big Sucker) and with added little things to install them. Pretty much all I need is the Cylinders, pistons, piston pins, rings and gaskets for reassembly.......correct? I looked into just those parts and if I were to order 2 sets of part number 16800003A (CYLINDER ASSEMBLY, W/ PISTON, RINGS, PISTON PIN & RETAINING RINGS (BLACK, NON-HIGHLIGHTED) from a 2015 FXDB, two cylinder gaskets, two cylinder base O-rings, two exhaust gaskets and four dowel pins, I'd be looking at $660.
Is there anything else I would need to make this change if I were to go this route? (I plan to do cams, cam tensioners, cam plate, push rods, re-tune when I do the rebuild and don't know if I plan to do any head work at the time)
I absolutely loved my 110, but I'd highly suggest the 107 kits. You can get a lot of power out of a 107 and pay less than the moco 110 kit. If you can get a tb in a kit you're better off cause they're ****in expensive separately. I like the HD kits but if you already have some of the parts they include, it's wastin money. I did the 117 kit because it included upgrades I wanted to do anyway like the tb, larger injectors, cams, etc.
cycler
Milwaukee Eight (M8)
06-12-2018 07:30 AM
RoadKingGibson
Exhaust System Topics
25
11-18-2011 09:20 AM
