Bent clutch lever
Old 06-03-2007, 04:19 AM
RazorFXDB's Avatar
RazorFXDB
RazorFXDB is offline
Default Bent clutch lever
I bent my clutch lever. I bent it out away from the handle bar. Does anyone know if it is possible to take it off and bend it back? or will it break?Would I need heat?
Anybody have any experience with this. It's not really bad, but I can't afford a new one and I don't want to break the one on there now.
Thanks for any help,
Ray.
Old 06-03-2007, 07:52 AM
piniongear's Avatar
piniongear
piniongear is offline
Default RE: Bent clutch lever
You can try to straighten it back the normal shape.....what have you to lose? Since it is a rather brittle casting, you may not have much success. My front brake lever broke off the ball end and I had (well, didn't have to, just did not know any better at the time) go to a dealer.......... $48!!!
I would suggest you get one from J&P if you wind up buying one.
Heat?........No, I would not recommend that as the material is an aluminum alloy and aluminum gives almost no warning before it melts. But then again, what have you to lose..........pg
Old 06-03-2007, 07:54 AM
jmpancoast's Avatar
jmpancoast
jmpancoast is offline
I am going to order a pair of chrome levers from eBay? I'd be glad to give you my old lever once they come in.
Is your lever usable in the mean time?
To be realistic, I imagine it would take about a week for mine to come in and get the old lever to you.
Old 06-03-2007, 09:15 AM
dc10sean's Avatar
dc10sean
dc10sean is offline
You can UNbend, IF you do it slowly using a block of wood and piece of pipe. Going VERY slowly, and in very small increments I have managed to unbend my wifes brake lever. Put pipe over lever, backed by 2x4 or similar block of wood. Gently bend back towards the grip.
VERY SMALL increments.
lee123
11-24-2018 08:34 AM
clhollister
04-26-2018 08:21 AM
JHL-ShinySideUp
Milwaukee Eight (M8)
11
11-25-2017 03:49 PM
glcash
2014-2023 Touring Models
01-14-2017 05:51 AM
kanddr
12-18-2014 06:08 PM
Quick Reply: Bent clutch lever
