Removing License Plate frame FXDL - WTF?
Old 03-21-2017, 12:42 PM
Twospot's Avatar
Twospot
Twospot is offline
Default Removing License Plate frame FXDL - WTF?
So I want to install the Kuryakyn lay back license plate frame. I went to remove the existing bracket. I have no clue how to get the 3 phillip heads out. The bracket is blocking access.
I checked the service manual and I can't find anything for the bracket. Can anyone shed some light?
Old 03-21-2017, 12:44 PM
davidwruth's Avatar
davidwruth
davidwruth is offline
Offset screwdriver
Old 03-21-2017, 12:51 PM
cggorman's Avatar
cggorman
cggorman is offline
Received 2,291 Likes on 1,710 Posts
What's on the back side? Captive nuts of some type or loose nuts?
I like my Chapman ratchet for stuff like this. Sometimes a 1/4 hex drive bit with a universal joint socket taped over it. Sometimes a bit with a combination wrench.
Old 03-21-2017, 01:28 PM
davidwruth's Avatar
davidwruth
I've had one of the Chapman sets for more than 20 years. They are great
Old 03-21-2017, 01:31 PM
fxdx1985's Avatar
fxdx1985
fxdx1985 is offline
Take the nuts off from under the fender
Old 03-21-2017, 01:54 PM
Nickd2689's Avatar
Nickd2689
Nickd2689 is offline
I took one off my in laws Fxdb not sure if it's the same brand, but looked identical. I took a long screwdriver and gently pulled the rear back a little and I was able to take it off. At work I often use a 1/4 inch socket and just put a Phillips bit in it. Another favorite of mine, but cheap craftsman screwdrivers, heat them with a torch, then bend them to where you need them. So far I have about 9 craftsman "special tools".
Old 03-21-2017, 02:05 PM
Twospot's Avatar
Twospot
Twospot is offline
Originally Posted by davidwruth
Offset screwdriver
Thanks for responding man, but not enough clearance
Old 03-21-2017, 02:10 PM
Twospot's Avatar
Twospot
Twospot is offline
Thanks as always CG and hope you're feeling well. After I saw this pic I ran out to Lowes (less than 1/2 mile from my house) and bought something similar. That won't clear it either.
So I stopped being lazy and jacked it up. There were loose nuts so I just cranked those out.
Funny thing is, if I had to put it back on, I still wouldn't have something to hold the phillip heads as I crank it back. Being a mechanical idiot though, these were locking nuts so maybe that prevents the philip head bolts from spinning as you crank them back in.
Thanks all for the replies.
Old 03-21-2017, 02:13 PM
cggorman's Avatar
cggorman
cggorman is offline
Sometimes you need to get medieval with your tools...
Old 03-21-2017, 02:27 PM
Twospot's Avatar
Twospot
Twospot is offline
LOL yeah I can see me losing some digits trying to do that!
Quick Reply: Removing License Plate frame FXDL - WTF?
