Battery or Charging System?
Old 03-07-2018 | 07:39 AM
skinman13's Avatar
skinman13
Originally Posted by cduemmel
Got a question here. I’ve been having an issue with my bike that required this procedure. When starting the cranking test, voltage dropped well below 9.6 volts and bike didn’t start. Battery or regulator? I’m going to pull the battery and have it checked, as that’s where I feel the problem is, but would like to hear other perspectives.
Start by putting a good 24 hour charge on the battery using an automotive battery charger set at 2 amps. After 24 hours, take it off the charger and let it cool off for about an hour and then check that the battery volts are at least 12.25 vdc static. If it is low, replace it. If it reads over 12 vdc cold static, do the cold-crank test you did again. If it is still dropping that low, crank it and check the charging volts...it should show 14 vdc absolute minimum. If the charging volts are low, check the voltage regulator and stator.
good luck
cduemmel (03-07-2018)
Old 03-07-2018 | 09:33 AM
Jackie Paper's Avatar
Jackie Paper
If maintained on maintenance charger, it's the battery. And even when you have it checked, there is a good probably 70% chance even if they say it is good, it is not. These small low amperage capacity batteries take sensitive equipment to really check. When they put that load on a fully charged one, just a few tenths off on the voltage and they are weak.
Old 03-07-2018 | 10:02 AM
cduemmel's Avatar
cduemmel
Stage IV
Well, Hopefully I'll know something this evening when I get it checked.
cobra23
07-19-2017 01:56 PM
ssbogger77
Electrical/Lighting/Alarm
06-03-2017 08:56 PM
JPD17
05-15-2017 07:00 AM
2012 Citron
13
01-09-2016 10:47 AM
Antnytro
01-06-2016 07:01 PM
Quick Reply: Battery or Charging System?
