Sissy bar installation
I had the shop install my license relocation kit as well as HD detachable mounting hardware for my 2015 Street Bob. My solo bag sticks out fatter than I'd care for. Question is how do I go about installing a rigid sissy bar? I am unsure what the original hardware looked like. Can I just unbolt the detachable pieces and Pip in the rigid sissy bar? Or do I need to remove the mounting bracket that's underneath the rear fender and use the original bolts?
then you can. Just put the factory bolts in in their place. No. If you already had the turn signals relocated you won't have to mess with em. If they weren't relocated you'd just have to run the wiring through the side plates but you shouldn't even have to depin the connector for that, just disconnect it, pull it through and reconnect it. It's very simple, I think you're overthinking this
This isn't my bike, but very similar. Except since mine is a 2015 it doesn't have that fender tail light. This relocation kit just extends the turn signals to allow for the the detachable hardware. Would I have to cut the wires and solder back together this way? It's just that main docking point that pushes too much into the bag. Plus I want to install the rigid sissy bar so have to somehow disconnect the turn signal anyway to get it there.
No cutting! Bad ju-ju. All the rear fender wiring can be disconnected at the underseat connectors and fed out. With the bike on the lift I can reach up under the fender and remove all the wiring and then get it back in the fender channels. No need to remove the rear wheel or pull the lower shock bolts.
Use blue tape and label the connectors, saves you some drama
kwrdkc (03-14-2017)
