Seating depth of mainshaft oil seal? No specs in manual
So long as you've no wear or corrosion marks on the mainshaft that would be close enough.
If you've any seal grease it won't hurt to use it sparingly on the lip of the seal if the new seal doesn't already have some when it comes new out of the packet. Or you can use transmission oil to do the same job.
Good luck with the work you're carrying out.
