Heat Demons
Heat Demons
My Heat Demon grip heaters came in today, and I did the install after I got off work. I HIGHLY recommend these if you hate cold hands and don't want to change to a different grip style. They go inside the bars and heat up whatever grips you may have. I really thought they wouldn't be that great heating up thru the throttle asy., but I was dead wrong. They have 4 heat settings, heat up pretty quickly, and were very easy to install with my stock Wide Glide bars which already had holes drilled to run the stock wiring. They give you a choice of clutch or brake mount along with chrome or black. The switch simply replaces the clamp on whichever side you chose. Here's some pics of the different heat settings, and all you see after the install.
techbill (02-24-2017)
I got part# 932927 which was clutch side, black in color. The kit comes with 3 heater elements depending on if you have cable operated throttle, or fly by wire electric throttle. They have you covered, and you won't use one depending on which throttle you have. Mine is a cable throttle.
I'd recommend you use the pigtail harness. That way in case you forgot to shut it off, it would get shut off when you turned the bike off. I actually used a relay to carry the load for my heated seat which uses the wire the pigtail harness will give you for switched power, and just wired the grip heaters into that as well.
I have looked at these for a while, my heated glove inserts are nice and warm, but very uncomfortable do to the bulkiness with the gloves. Only reason I haven't gone with the Heat Demons is because I have read that they aren't compatible with the internal wiring, don't know why, was thinking it might be the internal heat it produces and what possible damage it could do to wiring shielding. I would like to see if you have any issues later in the season that could be related to what I am saying. Can you tell me how long the wiring is that goes from bar end to bar end, wondering if it would be long enough for the apes I have.
