Getting Tased by the Plug wires....
Old 02-07-2017, 08:36 AM
cvaria's Avatar
cvaria
cvaria is offline
Received 2,201 Likes on 1,687 Posts
Default Getting Tased by the Plug wires....
On my last ride, i kept getting tased by the plug wires. I'm thinking that i might just go back to the SE wires but, i remember getting some stings from those too any one had this happen?
the shocks weren't overly painful. It was just enough for my brain to ask, "wtf, bro?" And cayse me to move my leg away for the bad place
I'm not in to moving coils but,, i think there were so heat advantages to moving the coils as well. Where are folks moving the coils?
Old 02-07-2017, 09:01 AM
beanoboy's Avatar
beanoboy
beanoboy is offline
Insulation on the wires must be breaking down...time for new plug wires !...b.
Old 02-07-2017, 09:36 AM
cggorman's Avatar
cggorman
cggorman is offline
Received 2,291 Likes on 1,710 Posts
Might wanna check your plug gaps before you get new wires.
I'm using MSD 8.5 mm wires and they're rock solid. Of course, I also hid the coil and routed the wires way up out of the way, so they would ground to the frame LONG before I got bit.
Old 02-07-2017, 10:02 AM
Nickd2689's Avatar
Nickd2689
Nickd2689 is offline
You shouldn't be gettin zapped at all. If you are, you need new wires. Never had this happen. Ever.
Old 02-07-2017, 10:27 AM
ripn's Avatar
ripn
ripn is offline
Definitely think your plug wires are breaking down, Grab yourself a pair of plastic or
WELL insulated pliers and start your bike when it's dark out, move the wires close to a ground source and you'll probably see the arching. CGGorman is on the mark as well, if your plug gap is too great the energy will seek the path of least resistance.
Old 02-07-2017, 10:59 AM
Nickd2689's Avatar
Nickd2689
At work (auto tech) we use water in a spray bottle and watch the mist as well as how the engine responds.
Old 02-07-2017, 12:42 PM
RedOregon's Avatar
RedOregon
RedOregon is offline
Yup. Last time I bought some purdy braided wires, they came with a steel spanner and wire to ground to frame!
Old 02-07-2017, 12:49 PM
cggorman's Avatar
cggorman
cggorman is offline
Back in the day overbraided wires were used to reduce EMI and the braid was grounded. Didn't realize they still did that.
Old 02-07-2017, 12:52 PM
Jackie Paper's Avatar
Jackie Paper
Jackie Paper is offline
Received 4,979 Likes on 4,171 Posts
It's a Harley..man up
Old 02-07-2017, 12:56 PM
RedOregon's Avatar
RedOregon
Well... that kinda was back in the day... on my '90 Sporty
Quick Reply: Getting Tased by the Plug wires....
