rear brake
02-01-2017 | 04:41 AM
rear brake
is this normal on a 2016 wide glide all bolts tight and caliper moves
02-01-2017 | 05:34 AM
it's a floating caliper on the rear. yes normal....
02-01-2017 | 06:19 AM
yes it on the rear and it moves a lot is this standed on all new harleys or just ones with abs
02-01-2017 | 06:32 AM
Normal for the newer style rear caliper to have some movement/play; my '13 Wide Glide is non-ABS...
02-01-2017 | 06:45 AM
Normal newer style, has nothing to do with abs. Abs does not affect the calipers.
02-01-2017 | 06:47 AM
ok thanks
02-01-2017 | 10:20 AM
Quote:
Originally Posted by
weasel76
Has nothing to do with being newer or having ABS...
If there are only pistons (not talking about pads) on one side of the caliper, then it has to slide to function as a "brake"
02-01-2017 | 11:39 AM
Floating caliper-normal. You can always look at the ones at your local Harley dealer like I did. However if you lack self control like me, you could end up buying something.
Unclescarhead
03-31-2019 08:12 PM
Vec
08-21-2017 12:26 PM
Khshockey44
EVO
04-22-2017 04:42 AM
bassrock
08-17-2009 10:55 AM
TxBikerMikey
08-09-2008 03:19 PM
