2015 FXDWG adding sissy bar but what parts do I need?
Was going to add a sissy bar/backrest to my bike for wife's comfort
HD website is very confusing on what I will need for install
Which parts do I need? Specifically, do i need the turn signal relocation? And which docking hardware?
Sissy bar
http://www.harley-davidson.com/store...senger-upright
back pad
http://www.harley-davidson.com/store...r-backrest-pad
turn signal relocation (one review says I need, other says no)
http://www.harley-davidson.com/store...-11-5396806--1
docking hardware A
http://www.harley-davidson.com/store...-01-5409710--1
OR
docking hardware B??
http://www.harley-davidson.com/store...01-5396406b--1
Thanks in Advance
Sissy bar
back pad
docking hardware A
OR
Thanks in Advance
Why not install a Bowman Welding bar with passenger pad and save yourself a boat load of time and trouble?
If all you want to do is add a bar and passenger pad don't waste time with that HD overpriced nonsense.
A 16" passenger pad bar for your Wide Glide ready to be installed; add the pad and you're golden, no relocations or docking hardware needed, no drama; I've got their 16" non-passenger pad bar. High quality, USA made
http://www.ebay.com/itm/2010-2017-HA...3D162293508037
This is the bar I used for my Wide Glide, absolutely first rate workmanship; the HD stuff? Meh...
You won't do a quick detach on the Bowman Welding bars; they're a direct replacement for the stock bar and mount exactly the same.
If your goal is to have a quick detach you may need to look at the HD offerings.
Personally, I'd go with the Bowman and just leave it on the bike permanently; their bars are beautifully made; the Wide Glide was made for a nice tall sissy bar, she doesn't look right otherwise
Received 2,201 Likes
i have the quick detach and it does need the quick detach hardware and relo since my signals are still on the rail.
docking hardware A
docking hardware A
i still have this low/sideplate version if you are interested. you'll still need the hardware quoted above. the sideplates give you a ton of options
ppalmerjr
Softail Parts
22
07-06-2012 02:18 AM
