tire bad?
Received 2,199 Likes
Yeah... It all depends on how deep it is. Like cggorman said, if it isn't deeper than the bottom of the sipes it's totally safe. If it does go all the way through, it would probably manifest itself as a slow leak (hopefully). You could inflate the tire to it's max and check pressure in the morning to see if it changed at all...
People ask me tire questions a lot at work, because I have a couple of YouTube videos about tires (on cars)... I always hate to say that a tire is safe, because tire issues can obviously escalate quickly. However... I've had very similar damage several times without ever having a problem.
On the other hand, I once wheeled my Triumph out of the garage, rolled over a cracked acorn shell, and had to replace the rear tire. The damage actually looked just like that, except it was in the bottom of a groove. Just freaky bad luck...
Received 5,740 Likes
First off, good on ya for seeing it. If it's not deeper than your sipes you're good. Take a small flat head screwdriver driver or a pick and probe it. If you don't feel belt you're good. Again, air it up to proper inflation and check to see if it's leaking. You could even try spraying a liguid on it, like Windex, or just poor a bit of water on it and check for a leak that way. If you see bubbles it's no good. If it's leaking and it's a new tire I'd plug it. Really just depends on how deep it is. I work at a tire shop part time. Ive plugged countless tires. Without seeing it in person it's hard to say. Car tires and motorcycle tires are completely different when it comes to safety. If it were mine I'd probe for belts. If I didn't feel any and it's not leaking I'd ride on it. Could have just had a small piece of metal embed itself or even a pebble but fell out.
