Should I dyno
Old 12-10-2016 | 04:56 PM
WH1_T-type's Avatar
WH1_T-type
Default Should I dyno
I've got a 2016 Low Rider S that I'm looking at adding Two Brothers exhaust to. The local shop wants just shy of 2K to get the exhaust, power commander V, install, and dyno tune it.
For under 1K I can get the exhaust and either a FP3 or PC V myself and install it all and do the butt dyno.
I will NOT be doing any more upgrades until the engine is dead so even though the FP3 doesn't have a lot of expandability, it seems like it would do what I need it to and it would be YEARS before I would need anything else.
My goal is just better sound and performance gains would be nice, but as long as I'm not losing Anything it isn't a priority.
Is it really worth paying all that money for a dyno?
Old 12-10-2016 | 05:07 PM
Mchad's Avatar
Mchad
Why oh why would a shop recommend a PCV for a bike that a Power Vision is available for?
For $999 you can get a fuelmoto e series or jackpot 2:1, a power vision and a lifetime of support and maps from one of the better tuners out there. I just ordered that same package today (e-series) for my Road Glide.
With the PV and autotuneing a Fuelmoto map you can get it pretty damn close to perfect. A dyno will get you that extra few percent if its worth the several hundred bucks to you...
Old 12-10-2016 | 05:10 PM
robbyville's Avatar
robbyville
Well here goes opinion number 1...
I would definitely buy the exhaust and either a FP3 (has more potential than you may think), or a Power Vision 2. Do the install yourself and if buying the PV2 get it from Fuel Moto with a canned map. They are incredibly close plus you can auto tune of course. With the PV2 you have a lot of options including getting a dyno tune later. Most shops will not tune with the FP3.
I did like getting my bike dyno'd, I found that he smoothed out the throttle better than the canned map or auto tune. But to be fair it was darn close.
Regardless of how you go, I would NOT use your dealer to do the dyno. They charge more and are very limited in what they can do since they will always work within the parameters of Compliance. If getting it done find an Indy with a great reputation.
Hope this helps and ride safe!
Old 12-10-2016 | 05:14 PM
robbyville's Avatar
robbyville
Just re-read your post and realized by "shop" you probably are already using an Indy so ditch the last part of my comments.
But this is post number 3000 so yay for me!
TinCupChalice's Avatar
TinCupChalice
Personally, I wouldn't waste any time with the PCV; if you're completely certain you won't be doing upgrades past the Stage 1 I'd get the FP3 and auto tune it myself. I went the Power Vision path since I know I'm doing much more but the supplied FuelMoto base map and auto tune runs have given me a ride that performs, and performs very well
I didn't and won't bother with any dyno tuning in the future as I make changes to the engine configuration. The FuelMoto base maps are that good
Do the exhaust and tuner yourself, but get your FP3 from FuelMoto; their maps are on the money accurate...
Old 12-10-2016 | 05:28 PM
TinCupChalice
Nice; you already have a Power Vision, don't you? Did you just buy a second license for your existing Power Vision or get a second? The license to add a second bike to your existing PV is $200...
Old 12-10-2016 | 05:45 PM
GWC68's Avatar
GWC68
At least do the install your self, the pipes are really easy to install. I did the PC V with a Fuelmoto tune and my bike runs great , pulls hard all the way through the power band.
Old 12-10-2016 | 06:01 PM
Ghost_13's Avatar
Ghost_13
Should I dyno
Yes
Bikes come off the show room floor no where close to optimally tuned - in fact its the opposite
So until you baseline it - doesn't matter what you add / upgrade
As for self tunes / butt tunes - wasted effort..., when compared to a "proper" dyno tune
Proper in parenthesis as not all tuners are worth a damn..., find one that is
You won't be disappointed
Ghost
Old 12-10-2016 | 06:06 PM
103luckygreenDude's Avatar
103luckygreenDude
I'd install it my self and find an Indy to dyno it. You save a boat load of cash and learn more about your bike.
Old 12-10-2016 | 06:18 PM
WH1_T-type's Avatar
WH1_T-type
Thanks everyone for the replies.
The shop I use is an independent in Alpine CA.
I know I won't be doing anything else to the engine because it is my primary transportation and it can't be down for more than a day (weekend). I put almost 100 miles a day 5-7 days a week, so the miles are stacking up. When this motor dies I'll most likely get an SS motor to just drop in and THAT'S when I'll worry about getting every drop of power out of it.
I'm looking at the fuel moto place now. I think I'll get all the stuff myself and install it and maybe dyno down the road.
Quick Reply: Should I dyno
