replace FXD tank
Did this on an 01; went with Wide Glide tank 'cause it uses larger, more common speedo and switchgear. Some FLH style speedo/tach combos are nice, others are useless with too little sweep for usable speed/rpm ranges. Nice to have on/off up on console. Not all Street Bob's have on/off switch and used a smaller unique speedo...the Low Rider is also missing the on/off switch and uses gauges that are smaller than Street Bob; similar to fork mounted gauges. What about Fat Bob tank?
I have a little experience with that
I did a complete overhaul last winter to my 06 fxdci. Started off just wanting to add hard bags and a fairing. Then I decided I wanted tunes so I added the hog tunes to the Memphis faring. Only after I bought it I realized I need to get the speedometer off the bars!! So I found a tank from an 08 Fatbob. Fit great except I needed to replace the speedometer cuz it was a different size from stock. So back to eBay for the console with speedometer. Everything worked good except the odometer is wrong since you can't change it on the older HDs.
red_headed_stranger
03-06-2014 04:39 PM
