I'd been running some Bassani Pro-Streets on my Dyna and while they work well with the 116 motor, I had to use earplugs when riding. I figured I'd try a RRIII as I know of some tricks to quiet the pipe down.
The Pro-Streets
I had clearance problems with the right footpeg.
The head pipe supports the tapered cone gaskets, One thing to note: Take the burrs off end of the pipe so the end does not tear up the gasket.
Problem was that the heads I have didn't have a lead in for the tapered gaskets.
After destroying a few of these gaskets, I made a tool to drive them in.
Hi Bwoltz,
A great thread you have going, the new pipe looks great!!! Did you also countersink the footpeg mounts for the allen bolts?
Nice clean work and relevant to something I'm doing as my pipe has a Cone Engineering muffler and I will sticking this in it, as a preemptive strike.
Once again, great work, I like your special tooling, and your Dyna is perfect.
: Mike
Reason: Add Stuff
It totally amazes me how many peeps on here buy what they believe to be the loudest damn pipe that they can find on the open market and then once it's installed all of a sudden they start complaining that it's too damn loud with out really knowing what a LOUD pipe truly all about and then how to tune it!
Hi Bwoltz,
: Mike
Yeah, Did that some time ago to help with clearance on the RR1 that was on the bike.
Your baffle looks like it fits in a straight muffler core. One thing I've done is find automotive glasspack mufflers do a good job with flow and can provide good quiet performance. YOu can by them in polished stainless steel so they actually look pretty good when installed.
Here are some pics of before and after of rebuilding a DnD pipe.. The SS automotive muffler weighed about 1/2 of what the DnD boat anchor weighed. Part of the reason for the change was the pipe was so heavy that with a big motor, bike shook like a paint mixer. It would snap off head studs every 500 to 1000 miles. I went to a lighter muffler, split the pipe at the Y and made it slip fit then added a mount at the tranny. No problems with the pipe since.
Great pipe surgery, I can't believe how much better your previous pipe looks after the primary tube trim and the muffler swap, but you do have a good eye. Thanks for the insight on the automotive mufflers.
