What did I drain out?
I went to change the oil (07 Dyna), and took out the wrong plug. I took out the plug facing the gorund, instead of the oil drain plug. What did I just drain, and what do I need to refill it. Also, where (which hole)do I re-fill it. I do not have a manual yet, and I am going to buy one for future reference. Thank you.
You either drained the primary or the transmission. The primary plug is on the left, and is filled by removing the 5 bolt cover directly above the plug. The transmission plug is on the right, and has a 7/16ths allen plug on top of it to fill through. You will need a funnel to fill the tranny.
Either one can be filled with formula+ from HD. However, I personally use mobil one full synthetic 75-90 in the tranny.
