Low Rider S: Any options to move gauges to bars?
2361 x1 - screws to hold the back plate to the gauges (they come in a pack of 5)
67319-95 x2 - tach cover without the button hole
67344-97 x2 - rear rubber grommet
63745-97 x2 - front rubber grommet
67338-97 x1 - tach/speedo mount
If you are using taller bars, you will need to extend the wires or buy the BBC harness, and find a way to cover the hole that will be left in your dash. It is super easy to do.
**EDIT - And WOW, just realized this was a thread started in October, 2016. Hopefully the info helped someone, I'm sure the OP has it figured out by now.
So I used a parts list put together by TheSSPirate on this forum. That is just a factory H-D tach/speedo mount for a Dyna, see p/n below. The mount is then held on by an L.A. Choppers gauge mount. I pulled my little fairing soon after buying the bike, so I'd have to say "maybe???".
The only thing that's stopping me from doing this mod is that I haven't seen an appealing way to cover the area on the tank formerly occupied by the dash.
Would it be possible to keep the tank dash, and fill the two empty tach/speedo holes with other gauges? If so, what type of gauges?
Thanks
Thanks for the detailed response.
Thanks
Thanks
been covered. covered at the begining of this very thread and several times here: https://www.hdforums.com/forum/dyna-...-quetions.html
you can put whatever you want there.... once you go custom, it's all up to you. own it, my friend
To cover the dash, I used a piece of kydex. It is crude, but cheap.
knscustoms.com makes a lot of the parts you guys are talking about. Very reasonable prices. I have done these on my bike.
I have a low rider s and want to leave everything where it is. It's not ideal placement but it's the traditional location for a low rider.
However I'd like to have a second speedometer that is small and reads as a bright digital display mounted either inside the top of the fairing or at the top of the handlebars where I can easily see it. One of those small sideways-oval shaped ones would do it.
How easy would it be to tap into the speedometer line and get a duplicate read out like I want? CAN bus may not make this easy?
Thanks for the details, this is making the process a lot easier.
Now for my dash solution. I'm thinking I'm going to build a phone cradle into it to hold my iPhone and charge at the same time. Won't be too hard once I have the mold built, so if it works out expect them to be available in a variety of styles.
rideon (11-29-2017)
https://www.hdforums.com/forum/dyna-...l#post16745300
