Update: Steering Lock Help.
Old 05-26-2007 | 08:12 PM
Faith's Avatar
Faith
Default Update: Steering Lock Help.
I just purchased an 04 Wide Glide, got it home and was checking things out. Locked the stering and now it won't unlock. Is there a trick or am I out for riding this weekend until the shop opens on Tues? Any help would be appreciated.
Old 05-26-2007 | 08:22 PM
Trotter's Avatar
Trotter
Default RE: Steering Lock Help. Urgent.
Wiggle the bars as u turn the key
Old 05-26-2007 | 08:31 PM
Faith's Avatar
Faith
Thanks, tried it and the key will not turn at all. You can hear a clicking but that is it. I will keep trying it off and on. Maybe it will work one of these times.
Old 05-26-2007 | 08:35 PM
edgar3's Avatar
edgar3
i have to "lean" on my bars so they are turnede all the way, then the key will work for me...
good luck
Old 05-26-2007 | 08:58 PM
Faith's Avatar
Faith
Still no luck. I will keep trying. Thanks for the replies.
Old 05-26-2007 | 09:00 PM
Biggol's Avatar
Biggol
ORIGINAL: edgar3
good luck
I grab the left grip and pull on it from over the seat so the forks are fully turned left. While doing that I attempt to unlock my forks.
One of my friends accidentally started their bike in first with thier forks locked and w/o using the clutch. When the bike stalled out it had put pressure against the wheel so when he tried to unlock the forks he couldn't get it. When I asked how he finally got it he said that he had to put the bike in nuetral and roll it back a little to get the tension off the neck.
Whatever the deal, good luck.
Old 05-27-2007 | 09:34 AM
Faith's Avatar
Faith
Still no luck so this weekend is a wash. I guess I will wax and polish it since it is just sitting here. Back to the shop on Tues. Thanks for the help.
Old 05-27-2007 | 10:20 AM
JBaker421's Avatar
JBaker421
Big Kahuna HDF Member
One more time? Try turning the key at the same time you are pushing and/or pulling the handlebars hard.
Old 05-27-2007 | 06:27 PM
jimsreddyna's Avatar
jimsreddyna
When I first got mine, I hada tendency to push in on the key while I turned. Don't push in.
Old 05-30-2007 | 08:57 PM
Faith's Avatar
Faith
After trying everything a locksmith was called yesterday. He worked on it for around a hour and drilled the lock out. The backing plate won't budge and the steering is still locked. So on the trailer it went to the shop. They looked at it and was amazed to saty the least. Good thing for the extended warranty and a helpful shop. Should be back this week including the new pipes and bars. Can't wait to get some riding in.
transam7969
07-09-2019 10:41 PM
Jesus Solorio
10-27-2015 10:03 PM
supermanotorious
11-03-2013 02:21 AM
TheGent
05-03-2010 09:43 AM
kingofsand21
03-10-2010 04:41 PM
