Dual Gauge / Micky Mouse Set-up Quetions
#51
#52
Received 2,199 Likes
#53
#56
#57
Delphi Packard Five-Cavity Wide-Range Crimper 22-12 AWG / 24-14 AWG, Made in USA, about $ 42.00
http://www.performanceplusconnection.com/Item/WHPT_11E
: Mike
: Mike
#58
#59
How are are you with a soldering iron? Splicing is no big deal but can get bulky if you use crimp connectors. IF you have to crimp, try to find (or make) non-insulated butt.splice connectors and use heat shrink tubing to insulate. Much slimmer. Also, remember to stagger your cuts so the splices are in different locations. Otherwise you end up with a big knot/cluster that can be hard to tuck back into the loom/frame.
#60
This link has good illustrations of solder and crimp splices, it will also put you to sleep
Link to splice instructions. Start at page 80 for solder splice. Crimp splice at page 85.
https://www.hq.nasa.gov/office/codeq/doctree/87394.pdf
You dont need to be this elaborate, I sort of go over the top...
: Mike
cvaria (11-07-2016)
