Grip replacement.
Grip replacement.
Looking to replace my grips that came on the bike. They're the chrome with rubber strips type and I don't like them. Ordered some basic grips for $16.95, but of course they don't fit, mainly on the left side they don't fit under the control housing. From China, should've known. Anyway, I'm just looking for basic grips that don't cost $100 like the HD Live to Ride ones. Any suggestions ?
Received 2,201 Likes
Doesn't matter,, I got the chinese knock off kuryakyn ISO and the left doesn't have that little lip to fit inside the grip,, but the key phrase is "doesn't have it",, so it's not sticking out any extra. Doesn't bother me that it's not there and nobody has walk up and pointed out the offending left grip non-fitting under control housing rubber part.
Use an adhesive (you must check the forum for the 100 types of forum approved adhesives) and all is good.
Lowbrow Customs has a nice selection of grips under $25. If you still have the throttle tube they just slip on with no fiddling with the switch housings. I use compressed air to remove and install.
http://www.lowbrowcustoms.com/motorc...by/1_inch.html
