I got my pipes
I got my pipes
Well my vance&hines big shots came in for my 5 superglide today.when i called some dealerships to get them installed, 1 dealership told me i was going to need a jet kit, air cleaner which brought the cost to over $500 to put them on. the other dealership told me i just needed the stage calibration. so for them it would be over $400. My question is "What do i need so that my bike will run well, and pipes will not discolor"
RE: I got my pipes
After I put my Big Shots and Ness Big Sucker on, I needed to get the carb rejetted because she was farting. I think any time you change the way the motor breathes (Intake/Exhaust)you create a situation where you need to monitor how it is running to see if you are creating a lean/rich condition. Check the plugs for color changes (There was a reference link on here somewhere to representative colors) and of course if she is farting like mine you most likely will need to rejet or remap/tune. Please correct, if this is not right.
Mark
Mark
RE: I got my pipes
I think you are going to need to do it regardless. What I was meaning to say is that, if you only put the pipes on you will probably need to rejet, then if you add a high-flow air cleaner later, you will probably need to rejet again, etc... etc... You may want to do whatever it is you are going to do to the "breathing" capabilities of the bike so you only need to rejet once.
Now, if you were to do something small like add Quiet Baffles later, you may or may not need to rejet, but looking at your plug color should tell you how its running.
I hope this helps and I am not confusing you more.
EDIT: Here is the link to the spark plug colorations I was talking about in my prior post.
http://www.dansmc.com/Spark_Plugs/Sp...s_catalog.html
Regards,
Mark
Regards,
Mark
RE: I got my pipes
thats wierd i found that plug chart last night when i was online. i didnt quite understand it though. i know what some fouled plugs look like but some of those plugs all look pretty close to the others. anyways what kind of air cleaner would be the best for me get for a decent price.
RE: I got my pipes
ORIGINAL: huntinjoe
