Fuel Injection Vs. Carboration - Pros and Cons?
RE: Fuel Injection Vs. Carboration - Pros and Cons?
ORIGINAL: SPECIAL ED
The Bob is my first bike with FI and I hate it.I'm not much of a mechanic but I can rejet one carb. I have not been able to get my Bob to stop popping on decel with the DFO niether has the shop where I bought the damn thing after three attempts. I gave up and bought a sert.Now that's 250 for the DFO + 400 for the SERT + god knows what for dyno tuning.I'll be over a thousand dollars just to get my bike to run "right" with a pipe and AC. If it were a carb I would have spent 1-2 hundred at the most on on a jet kit and spent an afternoon changing jets and I'd have been done with it.Hell for half half what I have into it now I could have had a local race shop tune it for me and it would have ran right the first time.
BTW what's a DFO? Must be like a race fueler?
I agree with mentor on my 05 Superglide I had the option made sure I got the Carbed one. Because as said here it is always easier to do anything on a carbed bike as far as mods go. As for the warm up and choke argument I think that is a poor excuse for not going for the carb. You can hop on the bike let the choke out ride off half way down the block and push it back in. Bike will run fine so there really is no warm up time. I am not so good with computers and that is one of the main things with a fuel injected bike to tune and get to run right.
FI is by far greater.
it can be tuned easier once accompanied by a laptop even by the shadetree mechanic once u know what your doing. obviously a proper dyno tune is the way to go even if you have a carb its still needed. though my first HD, its my 3rd FI bike and i can tune them much faster than a carb bike. maybe i just jumped on the FI bandwagon and learning curve earlier? I tweaked my own canned map from fuel moto, then i had a dyno tune done. can't say i noticed any big diff, maybe slightly smoother in midrange. it ran great before and after the dyno tune.
EFI bikes dont have the reserve feature.
Why loose the nostalga?
Longer to dyno tune EFI? Who told you that BS?
I just did a dyno tune on my '07 FXDL yesterday and we were making fuel mapping changes in seconds with the SE Race Tuner. The total time to dial it in was less than an hour. I could change out my cams, exhaust, and intake and do it again in less than an hour.
If anything, it takes longer to tune a carbed machine.
I run Boondocker boxes on my Arctic Cat F7 SP's and I was making fuel mapping changes right on the lake in secondsbetween races. Try doing that with a carbed sled.
After getting a bike with EFI, I will never go back to carbed. (Unless someone wants to give away a Shovel for a project bike real cheap).
The EFI starts right up every time no matter if it is 90 or 20 degrees. The PCIII is an easy to use tuner.
