Sorry, i meant that i was also going to use that same exact pic from googoo to add the Switchblade to the 17x4.5 mix because when i went to h-d.com it said "Rear", but showed the front. Then i ended up just leaving the Deuce in the post.
Sweet job! Looks like it came from the factory. Ingenious on your fairing mockup.
Is this all permanent or do you have quick release detachable bags and/or fairing? If I understood correctly, the fairing is fork mounted?
It is all permanently attached .. The fairing is fork mounted / the same way a touring model fairing is Fork mounted . It is not designed to be removed
