Gutted my stock muff's.
Since I plan on doing a pipe filter and SERT in the future, but don't have the coin at the moment. I decided to see what I could do to liven up the stock mufflers. So I took a 2" hole saw and cut through the welds, and then drove out the entire baffle from the inside out. Basically making them straight pipes. Surprisingly enough, it's still not all that loud. It definately has more bark. But it's not obnoxiously loud. Best of all, the bike seems a little more peppy. Just thought I'd share if anyone had thoughts about doing the same thing.
RE: Gutted my stock muff's.
i think even bamboo hollowed out is better than stock.I believe those stock baffles strangle the engine with its own exhaust. I went the the RUSH slip on w/ 2" baffles.Extra horsies right away and it is THE sound everybody wants( except my neighbors)
[IMG]local://upfiles/11023/BC3B6E25158B46329648D7F636581884.jpg[/IMG]
Just thought I'd update this thread after have ridden it to work this past week with gutted pipes. the bike definitely seems to have more poop. The bottom and midrange are stronger. Not dramatically so, but noticeable. the bike seems to have gotten louder too. It's still not obnoxious, but you won't be sneaking up on anyone. Even with the pipes gutted however, the stock exhaust necks down inside to about 1.25 inches inside, so at WOT, it's sounds a little funny. But at idle, cruise and 1/2 to 3/4 throttle acceleration it sounds awesome. [sm=biker2.gif]
ORIGINAL: dynaguy
Did you have to take mufflers off to do this ? Just how hard was it to do? Had a hd tech tell me due to taper of pipes you can not get baffles out. Would like to do this on mine. Got 07 WG. Would like more details on doing this. Thanks..
1) Use a 2" holesaw, attached to a drill, and completely cut through the welds at the outlet of the muffler. If you have a Dremel or small grinder, grind down the welds even further. This will help to get the baffle out easier.
2) Remove muffler. The mufflersare clamped to the pipes at the entrance of the muffler. They also have a brace that connects the two mufflers together.
3) Chuck up muffler in a vice, or have someone else holdit(I had a helper hold it).
4) Take a long bar or something equivalent(I used a piece of 3/4" steel rod approximately 3' long with the biggest size socket I could get to drop in there - sorry don't remember what size) and drive the baffle out with a BFH(Big FHammer). Drive it from the inlet of the muffler to the exit of the muffler. If the fiberglass packing stayed in there, reach in a pull it out with some pliers. One of mine stayed in the muffler, one came out with the baffle.
5) Reinstall muffler.
6) Repeat procedure for other muffler.
7) Enjoy the rumble.
The hardest part is driving out the baffle with a hammer. Them babies are well stuck.
ORIGINAL: RAPTORAZ
ORIGINAL: RAPTORAZ
