03 Superglide tank removal ?
I just got one of these for this application:
http://www.motionpro.com/product/12-0037
Someone here was kind enough to point out that you can get them for a little bit less direct from the manufacturer (cggorman, I think), but I couldn't find the link right now...
I think this will eliminate the need to drain the tank for removal.
Hose clamps. Don't be a monkey tightening and crush the tubing.
You can buy the pliers and bands as well if you prefer the factory style.
In a ah carp moment piece of thin wire,bailing wire looped around and twisted tight with pliers .
If hose feels as it glued on,just buy some more hose,cut it and get the tank off then split the hose off the tubing nipples. Might save a headache in long run.
Actually knew that, just couldn't think how to write my question describing the hose without 'halves'...b.
