Fuel Moto E Series Exhaust System for Dyna
#41
Just saw on the instructions that wrapping the head pipe voids the warranty apparently. I won't be wrapping it I guess. I'll install the remainder of the system tomorrow morning. Anxious to try it out. Downloaded the Propipe map into my FP3, I'll see how it runs with that map then decide to auto tune or not.
woodreaux (02-23-2020)
#42
Ok got it all mounted up. I can tell you that you need to follow the install instructions to the letter to avoid aggrevation. I decided to mount it using the hardware that came with it, so the stud that I used to space the bracket was removed. I ground some clearance on the gusset at the master cylinder, you can see by the pic that even with that it just about touches the plastic cylinder. Ran the bike with the ProPipe download and it's real close, I will probably auto tune it next week. As for the bag guys, I really can't see an issue unless you are using some really low hangers. Next stop is pulling the wheels and powder coating them Harley Racing orange and outlining the bar and shield on the tank in the same orange over the gold. Not happy with those wheels personally, ain't really gold, more of a camo brown IMHO.
#45
A file or Dremel tool could be used as well, but I have the tools so it was an easy job to recess it then smoothed it out with a Dremel tool and put a coat of Eastwood High Temp on the bare metal. As for the heatshield, haven't really ridden this one much since I changed the exhaust. It's 96 degrees out and very humid, not a great riding day or auto-tuning day. This Dyna will never see a double seat, bags, or any other two up or touring stuff, that's what my TriGlide is for. This is a total hot rod project. Very well may end up with a 117" kit in the next couple months.
#46
Thanks for the update.
#47
Yea if I ever have need to pull that muffler, like when I do the wheels, I'll grind a tad more off it, maybe another 1/8" at the high spot. I'll be able to mark it where the extra needs to come off with no guessing. It has a great sound, if you like super loud, get a ThunderHeader, this isn't that darn loud. The one on my RGS performed well and no nasty droning sound at highway speed like my Propipe muffler did.
#49
My hearing is gone for a few hours after riding with my current straight pipes. I was looking for something more subtle. Looks like your running the full 15 disks. I'm planning on starting with 11 or 12 and tune from there. Don't know if the number of discs make a db difference, but it's fun to play around with.
#50
Yes, I've had several SuperTrapp exhausts as well as an E series Universal on my RGS using a Propipe head pipe. When you remove discs, you will quiet it down and increase torque, of course just the opposite by adding discs. I find the sound very pleasing at 15 discs, a nice low authoritative rumble and the 110 will be happy. You may well not even have to remove discs at all. I don't think an open end cap is available for this ESeries but on a SuperTrapp, running an open cap vs the closed is akin to adding about 10 more discs to that system. I'm anxious to auto-tune it just to see how detailed of a tune I can get.
