Lazarus Project: 2012
Old 05-24-2017, 05:48 PM
cvaria's Avatar
cvaria
cvaria is offline
Received 2,201 Likes on 1,687 Posts
Originally Posted by TinCupChalice
Nice looking quick disconnect; added it to my bookmarks One thing, I've never seen any 1/4" fuel injection clamps anywhere. 5/16" is the smallest I've seen, I use them on my external crankcase breather hoses on the 3/8" hose to keep them discrete but the 5/16" clamps won't tighten up enough on a 1/4" hose. I ended up using black worm gear clamps on the fuel line crossover...
welp, dream crushed. i'll grab some worm drives
Oetiker stepless clamps like OEM (basically one-time use)
i had a run in with those on sportster replacing the oil tank. they are a problem. i didn't know what they were called though. new info
  #732
Old 05-24-2017, 06:14 PM
cvaria's Avatar
cvaria
cvaria is offline
found the source of the leak on the rear cylinder.. . mauled rear breather seal... how'd that happen?
the rocker boxes on these twin cams are torture! i spend near an hour getting them off. i'm need advice on the best way to get them back on and torqued, the rear box was straight from hell.
what are you all using to get them on and torqued? i did some BS to get them off but, getting them back on is going to be a different story.
No issues here... i did pull a stunt to get the heads of because the throttle body clamp screws were near impossible to get to... pulled both heads at the same time.
must be a tool to something to avoid that sort of stupidity.
bottom end is huge. doesn't seem that way withe the cylinders on but, damn!
How are we getting the ACRs out of the heads? any funky tools needed? edit..... never mind: https://www.hdforums.com/forum/engin...s-and-acr.html
  #733
Old 05-24-2017, 06:31 PM
multihdrdr's Avatar
multihdrdr
multihdrdr is offline
Received 2,314 Likes on 1,861 Posts
Originally Posted by cvaria
...i had a run in with those on sportster replacing the oil tank. they are a problem. i didn't know what they were called though. new info
There only a problem for those unfamiliar with using them ...they are a great clamp, specific in sizing
Pincers are cheap
  #734
Old 05-24-2017, 06:33 PM
F86's Avatar
F86
F86 is offline
Wow, your engine looks just like mine now!
  #735
Old 05-24-2017, 06:34 PM
F86's Avatar
F86
F86 is offline
Pincers are cheap
That's exactly what I used when I did my crossover...
  #736
Old 05-24-2017, 06:42 PM
multihdrdr's Avatar
multihdrdr
I became familiar with them here, just bigger versions...look familiar?
  #737
Old 05-24-2017, 06:47 PM
cvaria's Avatar
cvaria
cvaria is offline
Pincers are cheap
getting them on is no problem. It's off that is the issue.
  #738
Old 05-24-2017, 06:48 PM
cvaria's Avatar
cvaria
cvaria is offline
how much oil was waiting for you in the bottom of the cam chest?
  #739
Old 05-24-2017, 06:56 PM
cggorman's Avatar
cggorman
cggorman is offline
Received 2,291 Likes on 1,710 Posts
I need to get some of those crimpers. I like oetiker clamps but have always just used side cutters to crimp them...which suck ***.
  #740
Old 05-24-2017, 07:01 PM
F86's Avatar
F86
F86 is offline
Not very much at all, actually... Just a little bit in the bottom. I was way more concerned about how much tensioner material was waiting in the cam chest...
I think there are pictures in my thread showing about how much oil was in there...
cvaria (05-24-2017)
Quick Reply: Lazarus Project: 2012
