Lazarus Project: 2012
#401
Received 2,201 Likes
97%... brakes horn cover, reflectors...
brakes on and bled.
horn cover appeared.
High quality stuff. impressive
prepped rear rail covers for reflectors... (i know you all love it... REFLECTORS!)
installed the first set (lh,rh) on the rail covers
installed the second set on the one piece sissybar
#402
.... back to 75%.... Surprise motherfu****!!!
dropped the bike to add ride-on to front and back
dumped all that goodness in....
went back over all the valves to be sure i didn't do anything wrong and noticed that the front tire had dropped to 25psi from 38... in 10 minutes... there's smthing wrong.... grabbed soapy water and went looking for what I DID NOT WANT TO FIND.... AND I FOUND IT. Sgt. Doakes....
a horrendus leak.... from the spoke nipple... thanks Paughco!
*#%#% @%$%@ @^$%@ #%@ ! !!!! ^#$$%@^@ ^@^##$$$&*&$ (*&^$#@ !!!!!!!!!!!!!! FU**!!!!!!!
Return process started....
think happy thoughts........ hookers and popcorn Instagram.....
feel slightly better
moving on
these things are great
.............f*ck!
#403
#404
the valve is offset. i actually have a 21x3.5 tube sitting in the garage. one shop said do it, it will be fine; another said that i'd die a horrible death from the twisted tube.
what's the group consensus?
#405
there is a 2" DK lift. one on the first things i did because it was easy, lol
cvaria (09-22-2016)
#406
i started the return already. i'll just need to order another one and have the tire moved from one to the other.
#407
#408
i'm out my time and my bearings.... i will reuse the rotor bolts as they never saw real combat. cast wheels are a must in the near future.
there were bound to be some surprises. this last leg was too easy.
it's nearly impossible to fine an offset 21x3.25/3.50 tube.
there's no rush. i have another bike and i wasn't planning on using this one for anything major until mid october
#409
#410
