Lazarus Project: 2012
Old 09-14-2016, 09:54 PM
cggorman's Avatar
cggorman
cggorman is offline
Received 2,291 Likes on 1,710 Posts
I've got it and used it. I wish it was made of harder steel, but it works OK for the occasional use. The thrust bearing is a great idea. I used high pressure grease and felt it was still too much friction.
  #362
Old 09-14-2016, 10:13 PM
multihdrdr's Avatar
multihdrdr
multihdrdr is offline
Received 2,314 Likes on 1,861 Posts
You could always use this to drive them out
or use the Blind Hole bearing puller (slide hammer)
  #363
Old 09-15-2016, 05:35 PM
cvaria's Avatar
cvaria
cvaria is offline
Received 2,201 Likes on 1,687 Posts
Default S/S plug wires
Parts used:
Magnum ‘Sterling Chromite’ Silver Braided 8mm Spark Plug Wire Set for Dyna: http://www.jpcycles.com/product/300-235
Again.... S/S plug lines.
https://www.hdforums.com/forum/dyna-...l#post14687420
  #364
Old 09-16-2016, 07:34 PM
cvaria's Avatar
cvaria
cvaria is offline
Originally Posted by cvaria
Yeah, not cool. 9.99 buys problems.
Dollars to donuts, i bet the seller will refund yhe money an tell me to keep them.
donuts and dollars for everyone. .. full refund and keep them. Anyone want some free "conflict" covers.
Hopefully the Paughco hub is drilled better than the DNA!
The wheel is better quality but, the drilling issues are present. May just be a thing with these types of wheels.
  #365
Old 09-16-2016, 07:41 PM
cggorman's Avatar
cggorman
cggorman is offline
Ah well. At least you've got a wheel now.
  #366
Old 09-17-2016, 10:54 AM
cvaria's Avatar
cvaria
cvaria is offline
back-ordered foot peg support showed up. (shearing/corrosion fail from earlier in the thread https://www.hdforums.com/forum/dyna-...l#post15431593)
wheel and tires are now here. so close to being back to pre-tree status. i just want to rush... but i will not.
need to rehab the left caliper, rebuild the road glide m/c, swap bearings for timkins, and more... still quite a bit of work to go...
  #367
Old 09-17-2016, 03:14 PM
cggorman's Avatar
cggorman
cggorman is offline
Exciting! I would be chomping at the bit.
  #368
Old 09-17-2016, 10:07 PM
cvaria's Avatar
cvaria
cvaria is offline
Default fixed footrest mount with trust worthy part
replaced helicoiled temporary fix mount
new (top) vs fail
New t45 bolt
buttoned it all up w/ liberal anti-seize on the footrest threads.
done
  #369
Old 09-17-2016, 10:23 PM
cvaria's Avatar
cvaria
cvaria is offline
Default replaced paughco ABS and STD bearings with STD Timkin 205pp
ABS... bearing being yellow at me.
Pit Posse bearing tool(s)
brutal arm work, but the stock bearing where removed
the good stuff
didn't get the thrust bearings in the mail yet but, pressed my luck and tried to get them in anyway. they slid right in with anti-seize. no heavy arm work needed. it was harder getting the stock ones out. Thank you to Multihdrdr for the recommendation. i feel silly for not getting this before.. it paid for itself on first use.... and there are still more wheels to go.
sitting just where it should be. yes D's marking primary side. we don't want to repeat the reversed tire nonsense again. why D's? not sure what the logic was when i did that.. because...D...
  #370
Old 09-17-2016, 10:27 PM
cggorman's Avatar
cggorman
cggorman is offline
Sharp wheel.
cvaria (09-18-2016)
Quick Reply: Lazarus Project: 2012
