Lazarus Project: 2012
Old 09-03-2016, 09:22 PM
cggorman's Avatar
cggorman
cggorman is offline
Received 2,291 Likes on 1,710 Posts
Good to know. Thanks!
  #302
Old 09-03-2016, 09:33 PM
cvaria's Avatar
cvaria
cvaria is offline
Received 2,201 Likes on 1,687 Posts
Solid bushing s showed up fast... was not expecting that.
Cleaned inside the bushing holes. Added a little anti-seize (?)...
Rock solid. The wincup continues.
  #303
Old 09-03-2016, 09:43 PM
cvaria's Avatar
cvaria
cvaria is offline
Originally Posted by cggorman
I've never worked on forks. That's 1st on my list when I get back into the garage.
What's the big white PVC tube for?
Originally Posted by Reindeer
To pound the seals in the top of the sliders. Works perfect from my experience.
^this^
There's actually two tubes there, hard to make out in the pictures but, there's one to pound in (seal driver) the seals and another to get the first tube off the slider after pounding in the seal. I drop it down in the first pvc and tap it to break seal driver free. The 2nd is the smaller diameter pvc i used to drive the seal on my 39mm forks.
The following 2 users liked this post by cvaria:
cggorman (09-03-2016), F86 (09-03-2016)
  #304
Old 09-03-2016, 11:42 PM
cggorman's Avatar
cggorman
cggorman is offline
Good stuff. So, I should go get a couple feet of 2" sch40 for worling on 49mm fork seals?
  #305
Old 09-04-2016, 02:08 AM
cvaria's Avatar
cvaria
cvaria is offline
It's worked for me. I can't say it's a best practice.
  #306
Old 09-04-2016, 02:11 AM
cggorman's Avatar
cggorman
cggorman is offline
I've found that an understanding of the mechanics combined with good technique make more difference than having the special tool.
cvaria (09-04-2016)
  #307
Old 09-04-2016, 02:31 AM
SixDD's Avatar
SixDD
SixDD is offline
Location: Depends on who wants to know.........and why.
Received 1,902 Likes on 1,109 Posts
Me either!
  #308
Old 09-04-2016, 07:46 AM
cvaria's Avatar
cvaria
cvaria is offline
Originally Posted by SixDD
Me either!
The first time i did it with the practice set, i'm pretty sure i did everything yhe wrong way, 2nd time... not as bad, 3rd ... i was on rails, 4th .... changing engine oil seemed harder.
All the sludge there this time was alarming... it was grainy to. Not good. It was trapped up under the damper too, not in the slider. A draining would not have gotten it out.
  #309
Old 09-04-2016, 02:49 PM
TinCupChalice's Avatar
TinCupChalice
TinCupChalice is offline
Received 8,751 Likes on 3,962 Posts
The forks look fantastic, the chrome sliders are what belongs on a Wide Glide, glad you found the post on the fork fluid levels. I knew you'd like those LA Choppers solid bushings; solids baby, it's the only way to fly
cvaria (09-04-2016)
  #310
Old 09-05-2016, 05:40 AM
Tall Timber's Avatar
Tall Timber
Tall Timber is offline
Originally Posted by cvaria
[I]Old Man Ness seems to have changed how the adapters are threaded... but, why? Helicoil inserts.... Are there horror stories about failed Ness adapters that aren't being told?
Wow Helicoils how can that seem a better option that tapping a thread.
Quick Reply: Lazarus Project: 2012
