Lazarus Project: 2012
Old 09-02-2016, 09:01 AM
F86's Avatar
F86
F86 is offline
Originally Posted by cvaria
Alive and well.... yard in shambles... life is good.
The tiki torch didn't fall over?
  #292
Old 09-03-2016, 05:47 PM
cvaria's Avatar
cvaria
cvaria is offline
Received 2,201 Likes on 1,687 Posts
That tiki torch is hard as nails. Twice decorated. It killed the Predator, Arnold just took the credit.
  #293
Old 09-03-2016, 05:56 PM
NorthWestern's Avatar
NorthWestern
NorthWestern is online now
Received 6,274 Likes on 3,423 Posts
I love it. BMW in the driveway, scoots in the garage.
Glad the weather left you all intact.
  #294
Old 09-03-2016, 07:41 PM
cvaria's Avatar
cvaria
cvaria is offline
Priorities in tact
  #295
Old 09-03-2016, 07:55 PM
cvaria's Avatar
cvaria
cvaria is offline
Default Fixed gaskets on the oil cooler thermostat adapter
Fixed gaskets on the oil cooler thermostat adapter. Jagg actually rushed out two sets of replacement gaskets "on the arm". I'm impressed. "Thank you" to Jagg.
Gasket and goods
Old failures, actually ... only the halves gasket failed.
Blah...
Done
  #296
Old 09-03-2016, 08:13 PM
cvaria's Avatar
cvaria
cvaria is offline
Default Fear lift activated.... slider swap, fork rebuild
Finally started on the front end.
For posterity
Loosened axle bolt with wheel on the ground
Unleashed the Fear. ..
Pulled front wheel
Drained the fluid... oddly it stank like the fat bob practice forks and sportster fork oil did.... so i guess that the dealer i bought the dead 2013 fxdwg from must have actually serviced the bike fully since none of the issues i'm going to mention were present on the 2013 but, were here on the 2012.
  #297
Old 09-03-2016, 08:34 PM
cvaria's Avatar
cvaria
cvaria is offline
Default Fear lift activated.... slider swap, fork rebuild...more
Will update parts used later... cell phone sucks for this.
Tore down forks and found greenish-brown, thick sludge and corrosion. The sludge washed right out. It seemed to be sedimentary build up, nasty business. Even my 2007 sporty fors didn't have that kind of $÷!7 in yhere after 18k miles.... no idea what that was about. Glad i got it out though. The corrosion found around the cap threads and between the seals buffed and brushed right out. Good stuff.
Broke the new goods.
Slapped it all together. The new sliders cae with new seals but i opted to fully rebuild. Extra expense but i feel warm and fuzzy about it. Added only 500ml of oil to each fork... couldn't remember what tincup said was supposed to go in and there was no netork coverage or power. will address later
Found: https://www.hdforums.com/forum/dyna-...l#post15126601
  #298
Old 09-03-2016, 09:02 PM
cggorman's Avatar
cggorman
cggorman is offline
Received 2,291 Likes on 1,710 Posts
I've never worked on forks. That's 1st on my list when I get back into the garage.
What's the big white PVC tube for?
  #299
Old 09-03-2016, 09:06 PM
cvaria's Avatar
cvaria
cvaria is offline
Default Ness rotor..brake caliper clean up, pads... sgt. Doaks...
......... surprise
Old Man Ness seems to have changed how the adapters are threaded... but, why? Helicoil inserts.... Are there horror stories about failed Ness adapters that aren't being told?
Wheel up on shiney forks..
Scrubbed up caliper and added in new pads.
Bled off some fluid, adjusted pads, mounted, and tested brakes. Good to go. Added reflectors ... don't care, I'd rather be seen than be cool.. noticed that the rear reflectors were missing... will be picking up some of those.
Flat slider caps look the business with chrome sliders
Flatness
Must get black axle covers nut this time
Dual disk ready.
  #300
Old 09-03-2016, 09:18 PM
Reindeer's Avatar
Reindeer
Reindeer is offline
To pound the seals in the top of the sliders. Works perfect from my experience.
The following 2 users liked this post by Reindeer:
cggorman (09-03-2016), cvaria (09-03-2016)
Quick Reply: Lazarus Project: 2012
