Lazarus Project: 2012
#1101
Received 2,201 Likes
tried out the leftover black headlight bezel from the crappy funlove headlight bucket i installed on my sportster.
#1102
#1103
Mcmaster-carr you think?
#1104
Mcmaster-Carr would certainly have them, but you can get them locally. There was a time when "Every" SS worm drive clamps was All SS (didn't have to say it on the clamp). Now Cheapness has set in.
https://www.homedepot.com/p/Everbilt...-202309380-_-N
cvaria (03-18-2018)
#1105
i'll pick them up later.
#1107
finally got around to swapping out the worm drive to the ss one Multi recommended. Started at it the day he said get them but was a PIA to get the clamp through the loop on the heat shield without taking it off the pipes... kept walking away after 5 minutes of shucking and jiving. Only took 4 days.
all engine shined and good to go.
slvrscoobie (03-22-2018)
#1108
#1109
For ROCKOUT information & purchasing please click HERE For all Twin Cams and Evo Big Twins & Sportsters
__________________
NO, they DON'T all do that!
Also on amazon.com...
cvaria (04-01-2018)
#1110
Follow on from humbling drop incident: https://www.hdforums.com/forum/dyna-...l#post17291384
Readjusted /replaced:
damage:
- Right controls shift from impact
- right turn signal trim ring die a horrible death, was replaced with a spare
- right turn signal stem nut was knocked loose. Tightened, good to go
damage:
- megaphone seem to have been knock out of round and has a nice shiner now.
- Lower/front heat shield scraped pretty good.
- Pedal slapped the heat shield. . Probably kept damage to rest of yhe bike down.
- Rear brake pedal bent.
- right grip is gnarled up
