Brake won't bleed. Any Ideas?
So yesterday I pulled into the dealership on the way home from a 500 mile day and when I went to leave my rear brake was sticking. I reached down and pulled the brake pedal up and that freed it till I got home. Today I checked the fluid and it looked dirty so I changed that out and added new. I also took the caliper apart to check the pads and they were fine but noticed one of the cylinders was stuck down. A little brake cleaner seemed to free it up. Put everything back together and went to bleed the lines with my vacuum and thirty minutes later still nothing but air. Any one have any Idea what to check for. O ya one other thing I picked up a new bleeder from my local Indy and it was slightly different than the stock but he said it don't matter. The bleeder did appear to seal as I could not pull a vacuum when it was closed. Bike is a 2012 wide glide
Did you bleed the banjo bold too?
Sometimes you gotta bleed the master cylinder.
When I bleed brakes I do this order:
Take the line off the master cylinder. Hold your finger over the connection where the brake line goes, pump the pedal/lever. That pumps all the air outta the master first.
Connect the brake line, bleed the banjo bolt. No air outta that.
then bleed the valve.
If you've done all that the right way, sounds like air is getting in the system somewhere. Bad seal or somethin dude. Good luck.
Lotaluck (06-06-2016)
I have the caliper at my Indy now to have the seals checked.
Received 4,632 Likes
Sounds like you have an air leak, and since it was working till it stuck, most likely culprit is the stuck cylinder seal, whatever was sticking got in the seal and is letting air in. Hopefully your indy will put new seals in it while it's off, doesn't cost that much and now's a good time to do it off the bike. Let us know if that cures it.
If you're putting the caliper back on yourself, and still don't have brake pressure after you're getting clear fluid out of the caliper, close it at the bottom and exercise the pedal, you may see a small stream of bubbles come up in the master cylinder and when that quits, you should have pressure. Word of caution, pump a pedal or lever fast, and if the master cylinder isn't covered, it can spit fluid out.
