Lowrider S rear fender brake light
Anyone know what (if any) rear fender brake light strip will fit on the lowrider S? I'm talking about the one that's a row of LED's that you stick to the underside on the back of the rear fender. Last time I was at the dealer they said it wasn't available yet. When I measured what I needed it was different than what I could find on fleabay. Sportster one was a little short (might work though) and the other one was too long.
I've got a 2016 FXDLS .
The Canadian bikes are not fitted with a side mount licence plate , instead , a plastic , fender mounted licence plate bracket and tail light arrangement , it is hideous.
I Pulled all of that off and installed a licence plate bracket kit from Great Bike Gear along with a l.e.d. light that fastens under the rear fender . Much nicer looking.
http://www.jpcycles.com/product/712-...id=CSE_shopbot
I got the light from Parts Canada (Drag) .
http://www.greatbikegear.com/index.php/stbms.html
The bracket kit , I ordered from Great Bike Gear.
The turn signals are now mounted further back and docking hardware is on the fender rails
I'm very interested too. Especially on the installation and functionality. Does it act as a run brake turn light? I also have the GBG plate mount.
Edit: If only I read in more detail. I see its only run/brake. Which I really prefer. Excellent.
I should mention , I modified the licence plate bracket I bought. I changed the profile of the upper edge to accommodate the l.e.d. light assembly and I removed the bracket that is supposed to be used to install the licence plate illumination lamp that comes on the side mount plate bikes. Once I was happy with the fit I re sprayed the bracket with Harley Wrinkle black rattle can spray paint. It turned out nice .
Sorry fellas , I didn't take any pics yet.
Here's what it looks like , I did some trimming to make it work , not a big deal , fabrication / metal working are one of my hobbies.
I had it in my workshop for it's first service today , assigned my Screamin Eagle race tuner and loaded a canned map for now , tweaked the rev limit , made sure anti knock was enabled , disabled the temp management. Installed an oil cooler too , the verticle mount one from the MoCo.
Shaved Ice (04-01-2017)
