Stripped Exhaust Port Threads
Helicoil...but that front top stud points directly at the frame. It may be difficult. If you can't drill it absolutely straight, you may have to pull off the head to access it.
In the future...the torque on the exhaust is only 60in/lbs, or 5 ft/lbs. If you cross thread anything, 60 inch/lbs is not enough to strip the threads. It just locks up.
Wise words to live by. That & if you are tightening a fastener & it starts to bind up, don't force it. Take it apart, inspect the threads & if necessary replace the bolt or nut or chase the threads with a tap or die.
My son used to get frustrated with me in the shop because I work slow and clean everything before reassembly. He hated cleaning threads and painting brackets.
He's spent the last couple months fighting with his 86 Yamaha that had PO with very poor work workmanship. He is the guy in class that all the other guys call when they need help. I come home to all kinds of random **** parked in the drive.
After fixing a lot of other's mistakes, he now greatly appreciates the benefits of doing it right. He really bags on poor quality work. Makes me smile.
robbyville (06-03-2016)
I've seen studs come out of the head all the way or just partially as you take the exhaust off, then they turn when re-installing but they are not stripped. Just a hopeful thought...
-G
If access isn't a problem, consider a Time-Sert ... Much easier to use ( especially for a "novice" )
http://www.timesert.com/
