Replacing Final Drive Belt - Do I Need to Remove the Rear Wheel?
Old 05-29-2016 | 12:39 PM
Stiggy's Avatar
Stiggy
The only reason is Dealer cost. I run a Falcon SPC and have not had an issue but there were complaints on bikes with narrower (than my 1.5") width.
Gates still makes the OEM belts (unless something changed,) and their carbon fiber 'Polysteel' is supposed to be even stronger (and cheaper if you go aftermarket.) That's how I'll go next time (if this one ever breaks.)
Old 05-29-2016 | 12:54 PM
TSheff's Avatar
TSheff
While you're in it and this far down are you happy the pulley ratio? If you ever thought about changing now would be the time.
Old 05-29-2016 | 12:58 PM
F86's Avatar
F86
Originally Posted by TinCupChalice
If you're concerned about doing the rear wheel alignment pick up a Motion Pro #08-0368 alignment tool. It makes the job quick and accurate. Sure, you could make an alignment tool out of some bent wire but who doesn't like nice tools?
If you don't have a belt tension gauge get a Motion Pro #08-0350 gauge so you can properly set belt tension.
You can find both of those on eBay inexpensively...
+1 on this...
I just used both of these exact tools this past week. They are both things that you could replace with a tape measure, but they're inexpensive and pretty fool proof. I set the pointer on the alignment tool against my axle before removing or loosening anything, figuring that would be a good starting point for reassembly. As it turned out, I didn't really have to readjust anything. I just lined up both sides to the original pointer location and both alignment and belt tension checked out. Super simple!
Old 05-29-2016 | 01:32 PM
hAkron's Avatar
hAkron
I went with the OEM belt. I didn't realize until after I paid though that he didn't have one in stock and he had to order it...so I won't actually have it until Thursday, which is fine, I can't get too far until my alignment tool gets here anyway.
Old 05-30-2016 | 09:24 AM
GREENOHAWK69's Avatar
GREENOHAWK69
I used a car jack under the tire when re-installing the axle for belt replacement. I've had to remove the rear tire and axle twice, as well as, both primaries for repairs. As others have said, read the manual and take your time. I did this and had zero experience before doing this...and I'm still living to talk about it.
Old 05-30-2016 | 09:39 AM
fskitch's Avatar
fskitch
You can make an alignment tool (Wheel alignment right?) out of a coat hanger and zip tie.
Works perfect for me.
hAkron (05-30-2016)
Old 05-30-2016 | 12:22 PM
imboden's Avatar
imboden
I did all this on my wife's bike. The rear pulley bolts sheared off and the final belt broke. Lucky nobody got hurt.
anyways, wish I would have just bought a chrome inner primary.
Ozark Joe
EVO
19
05-22-2017 10:13 AM
terrysillik
09-09-2016 09:23 PM
Candubrain
08-04-2014 08:34 PM
Galdog
03-14-2011 04:51 PM
I CUT 1
02-02-2008 06:26 PM
Quick Reply: Replacing Final Drive Belt - Do I Need to Remove the Rear Wheel?
