Thundermax install on 07 FXDWGI
Old 05-20-2007, 12:15 AM
intempestivus's Avatar
intempestivus
intempestivus is offline
Default RE: Thundermax install on 07 FXDWGI
You go through what they call an IAC stop setting routine once you are ready to fire up the bike. Essentially you start with a cold bike, crank it up, let the idel stabilize and then initialize the IAC setup. You can watch on the screen as adjustments are made up to 289 degrees (head temp). Once you reach that temp you shut it off and go back to where the point on the graph where the first adjustment was made and begin smoothing out the idle rpm curve until you get to where there is a gently sloping decrease in the line between cold start idle and normal operating temp. I made maybe 6 or 7 adjustments over the entire span and they were small. The T-Max adjustments were pretty close. I guess you could say it's part computer part manual. At least that's what the instructions tell you to do. Mine idles better than it ever has now.
cwsharp
11-23-2012 10:15 PM
oldguyriding
11-14-2011 02:18 PM
BLK08ROCKERC
04-23-2010 07:44 PM
B-EZ
09-15-2009 08:48 PM
baldjohnny
07-22-2007 12:00 PM
Quick Reply: Thundermax install on 07 FXDWGI
