New master cylinder rebuild kit and still wont push brake fluid out.
I have replaced the plunger and spring and seals but yet the master cylinder just does not push any fluid out of the banjo bolt hole to even get to the brake line to get to the caliper... So confused, I even see the plunger going back and forth through the little hole.
So what can be wrong with the MC besides the plunger and seals?
Thank you for the help.
Chris
Chris
Received 2,201 Likes
Chris
Chris
front or rear?
Front----
try keep your threads together, and not start another if it's a continued issue.
https://www.hdforums.com/forum/dyna-...r-pistons.html
slow down and address one issue at a time. try this:
hopefully your piston pops out.
cover your paint to keep the fluid off it.... it will ruin your paint
https://www.hdforums.com/forum/dyna-...-pressure.html
- Connect the mc to the brake line and disconnect the brake line from the brake (probably already is considering your piston issue).
- fill the mc with fluid and just let it hang over catch pan -may take a few minutes or so.. will not just come rushing out
- the fluid should work its way through the mc and out the line.
- attache the caliper and do the same thing with the bleed nipple open (gravity bleed)
- once fluid is coming out of the bleed nipple, close the nipple and start pumping the brake to build pressure.
i had the same problem a few weeks ago. I rebuilt the caliper and replaced the master. still no go. i hooked up a vacuum pump to the bleeder. Nope. so i got a syringe with a hose on the end. filled up the syringe and pushed fluid from the bleeder to the master. I now have brakes. i was also told it could maybe the line. just a thought. And yes i bled the master, and filled the caliper up with fluid before putting it on
