Fat Bob brake upgrade?
Afternoon everyone. I have a 2008 Fat Bob. Brake fluid has been done recently and pads are good, low miles with 7500 on the bike.
I come from sport bikes and some track days. I personally think this bike stops really poorly (and I'm sure the extra 350lbs contribute to that).
I've seen caliper brackets from Speed Merchant to use sportbike calipers, a little spendy but was wondering if anyone has tried them and what the results are. Are there any Master Cylinders that can be swapped over easily and fairly inexpensively?
I still keep an R1 in the stable, and going from bike to bike can be a been unnerving when I'm used to braking on the R1.
Hey jjminch! Did you ever get that 30T done?
I kinda went a pricy way with my brakes, bought Matric composite rotors and Lyndall Xtreme pads - works great for me, a smooth controlled braking that really can put the bite on if you keep pulling.
Received 2,199 Likes
i'd try steel lines and lyndall pads first.
i used
Goodridge fatbob stainless steel line kit 03-1120 (~$120) - Goodridge Econoline Brake Line Kit Front fat bob amazon may say it doesn't fit... it does
Lyndall Racing Z-Plus Front Brake Pads for 08-up Softail and Dyna 7256-ZPLUS (2 X $44.95) - http://www.easternperformance.com/ly...-and-dyna.html
i used
Unfortunately I never got to the 30T. Same month I wanted to meet up with you last year, I had to relocate to Atlanta permanently. Appreciate the input on the pads and rotors.
i used
i used
Appreciate the pad info and might just give the that route a shot.
As far as pricing, I'd like to stay under $300. I'm just used to being able to use cheap take off parts off different bikes to upgrade components. Plus I want to save some funds for a suspension upgrade at some point.
