Removing stock sissy bar from 13' fxdwg
I have read some threads, but I'm still confused...trying to put new rigid mounts on along with new bar. Can't slide out old plates. - Strut bar is blocking it, tire blocks inside bolt from
completely getting out, and i dont have a lift. How difficult is this job? Do I need to unbolt
top of shocks. I'm hoping to do this myself.
RottentotheCore (05-17-2016)
I'm not sure how different the '13 is from my '99 but I had to remove all the bolts from the fender struts to get the plates out. That included the turn signals. The seat and shock ~should~ be able to remain as long as you can get under the fender to remove all the bolts. Then the plate should slide out. If you lift up the bike and the tire is still in the way, you'll have to take the shocks off to allow the swingarm to drop even further.
Removing the shocks is easy. Just two nuts each and they slip right off.
I did see that thread...a lot going on there, I didn't think to remove fender. I'll get it on the lift take out
the inside bolts, then outer bolt on strut cover. Here, I 'll try to remove the strut and slide it off. If I need to pop the seat and remove the shocks I'' do it too. I have to get torque measurements. Thanks man.
