Mag wheels
Old 05-15-2016 | 07:08 PM
mock24v's Avatar
mock24v
So is it possible to be able to get these on my bike or no?
Old 05-15-2016 | 07:10 PM
cggorman's Avatar
cggorman
Anything is possible. Probably not practical, tho.
Old 06-02-2016 | 04:19 PM
mock24v's Avatar
mock24v
if i find some wheels 2006 and up can someone send me a link or maybe give me a procedure list and a parts lists if at all possible
Old 06-26-2016 | 07:41 PM
mock24v's Avatar
mock24v
so im buying a set of 13 spoke mag wheels. can anyone give me a parts list and tell me what to do to put them on my 2007 streetbob. i dont care how much this is going to cost me, i just want them on my bike
Old 06-27-2016 | 07:42 AM
cggorman's Avatar
cggorman
You'll have to either modify your forks to accept a 3/4 axle (possibly split bushings) or modify the wheels to accept larger bearings...or dig deep and find bearings that will do the job. you'll probably require custom bearing and axle spacers regardless.
I'd be surprised if there is parts list or procedure published. Somebody may have done this, though. Hopefully they find you...or you them.
If cost is no object and you aren't planning to do the work yourself, you're best recourse is probably to find a good custom bike shop and cut a check.
Old 06-27-2016 | 08:28 AM
multihdrdr's Avatar
multihdrdr
Do have the 2000-later 13-spoke wheels in your possession?
Is one or both 2000-2007 wheels that came with 3/4"-1" x 21mm wide bearings or 2008-later with 25mm x 15mm wide bearings?
Old 06-27-2016 | 08:43 AM
multihdrdr's Avatar
multihdrdr
Whoa c-man, there will be none of that crazy talk
Might be the best and likely process
Joey Pennington
09-24-2019 02:52 PM
Clmartin93
05-02-2019 06:23 AM
Bspike1
06-29-2012 05:46 PM
jsbridgew
07-28-2011 12:45 PM
bdbaggr
11-10-2010 05:13 PM
Quick Reply: Mag wheels
