Just got a 2015 Wide Glide, Need Bars ASAP!
Hey everyone, just picked up a lightly used 2015 Wide Glide last night (with 441 miles on it) and I love almost everything except the bars.
Has anyone replaced the stock bars on a late model Wide Glide? Are the stock risers the 1.25" or do they step down to 1 inch. I am looking at bars like the ones attached, but need to know if the risers have a step down or not.
Also, what am I looking at for cables and wire extensions?
Man, I'm excited and appreciate any help I can get.
Thanks for the heads up, I guess my next question is, would it be easier to change out the risers for 1 inch ones, or to find 1.25 in bars to fit the stock ones, it seems like 1.25 inch bars with knurling are pretty tough to find.
I just ordered a set of Mayhems' from KST and they knew that they didn't step down. Chances are you will be getting s shorter set of risers anyway, so you can order whatever you decide in the end. those tall risers wont look so great with a set of mini apes in my eyes...
Burley doesn't list a kit for the 15 wide glide because of the ABS. But I am not at the point where I am ready for the expensive part yet, so I have not looked too hard. fixing one bike at the moment, so I cannot tear into the wide glide yet.
I just ordered a set of Mayhems' from KST and they knew that they didn't step down. Chances are you will be getting s shorter set of risers anyway, so you can order whatever you decide in the end. those tall risers wont look so great with a set of mini apes in my eyes....
So far Magnum Shielding is the only one I can find for 2015 WG with ABS.
It's a little spendy, anyone have any experience with these cables?
https://www.magnumshielding.com/handlebarkits-387142
The kit looks really nice too with the stainless cables and lines, I really wish Burly made one of their $200 kits for my bike though, would have saved me some dough and I really wasn't set on the stainless look.
I installed them Sat and Sun over the weekend. Took forever (was my first time). I just bled the brakes like normal (with a mighty vac) to dry out the front system, took the old cables off and did the job.
After the bars were on I hooked up the new brake line with new washers, torqued to spec and used my vacuum bleeder to pull fluid into the system. I cycled it through a couple of times to get the air bubbles out.
The brakes were a little spongy at first but once I got out on the road, the ABS stops flashing as soon as I take off, just like normal. Tested the ABS on my second test ride yesterday after getting it all put together. Hit a quiet side street near the house and from about 40mph I slammed on both brakes to simulate an emergency situation. One small peep out of the front tire and then it kicked in and stopped safely and abruptly.
YMMV but I say this job can be done on an ABS Dyna without going to the dealer. I will keep an eye on the ABS light to make sure everything remains normal, but I think if there were any problems, I would have noticed them on my 3 test rides yesterday.
